I've read the sticky on trouble shooting the ignition, and so far I've found this:
Engine starts fine in the middle of the afternoon when it's hot outside, but will not start early in the morning or when cooled off at night. I have yet to see any spark coming from the spark plugs, the used old ones, or new ones either. The old spark plugs look a little oil fouled too. I hooked a plug directly to the coil and couldn't see any spark at all when I turned over the ignition either.
I checked under the distributor cap for water or condensation and found none. I'm gonna get my dads timing light and check for spark signal by induction as well. My coil reads 2-4 ohms on the primary, and 10,5k on the secondary...
I haven't had time to do much more troubleshooting, but this is where I'm at right now. I just thought I'd ask if anyone has seen this before. It's a '92 Sea Ray fyi.
Thanks.
Thanks.
