4.3l mercarb rebuild hard restart
boattoy
So yesterday I rebuilt my mercarb (4.3 v6 1989 engine) after dealing with the way it ran for years! Needless to say I should have done it years ago. Boat has always had an off idle roughness and hated running between 1200-1800 rpm. I found some passage ways dirty. Anyways got the carb together and she fired up with just a bump of the key. I adjust the idle and air screw (or fuel screw? Idk) so it’s smooth at idle. Then off to the lake I go.
Get there and the boat doesn’t want to start, I crack the throttle and she fired right up. Rip it around for 20 mins(runs amazing!), shut it off to check for leaks , go to restart 10 mins later, again have to crack throttle and now I need to give it a quick rev or two because it’s stinky Rich.boat clears out and idles/runs perfect again. I m thinking maybe air fuel screw is too far out. I adjust it so it runs a little rough and barely back it out less than a 1/4 turn (out about 1.5 turns). Boat idles steady at 800 , I take it for another spin for 20 mins , shut it off for 20 mins , again I have to crack the throttle then a quick rev to clear it out. Did this a few more times same result.
So the Only thing I changed during the rebuild setting wise was the float level from about 5/8-3/4 (what it was at forever) to the recommended 3/8” which brought the float drop level to a perfect 1-3/32 according to oem kit I bought(running solid needle like before) . I’m thinking lower the fuel level back down in the bowl? I could live with it but Ide rather fix it . Suggestions? Btw I adjusted the choke so it’s mostly open , I run the boat in 80+ temps only .
thinking the float level is too high and the needle is leaking
adjust your choke with a cold motor, it will help with your starting.
Ayuh,..... Which carb,..?? 2bbl,..?? Mercarb, or rochester,..??
4bbl,..?? Quadra-jet,..?? ABF/ Merc- Weber,..??
Rick Stephens
Title says Mercarb. Makes it simple.
As Scott noted: float level and seat most likely. Did you get a complete kit for rebuild?
boattoy
Bought the oem quicksilver kit and set float (plastic) according to spec sheet that came with kit . I never had fuel starvation issues before with level a lot lower in bowl .
TurtleTamer
Sounds to me like float level is off. Does it drip fuel from the venturi cluster after shutdown? Reason I suspect too much fuel vice too little is when you crack the plates it starts for you. I ran my carb for a whole season like this before I realized the dripping fuel wasn't normal. Had the same issue as you. It did run fine but starting was never easy. Different motor but same carb.
boattoy
I didn’t have enough tools in the boat to pull the arrestor off and it also requires unscrewing a cover to get to carb. I was suspecting that could be a possibility , I have no idea why mercruiser changed the specs to such a high fuel level in the carb. Especially on an engine that’s get bounced around a lot . Thanks for the help, I’m def going to lower fuel level in the bowl first and try it. Super simple to remove top plate .
