Hey all,<br /><br />I have a 93 Sun Ray Bowrider I purchased over the 4th this year. The last couple of times we were at the lake, we noticed a leak when the boat was sitting. Here are a couple of the observations I have made about the leak:<br /><br />1. It doesn't leak much when underway (at least it doesn't seem too bad. It is hard to judge, since all we do is ski and tube, so lot's of wet bodies in/out).<br /><br />2. When left overnight in the water, if the drive was pretty much straight back, not much water came in, maybe a gallon overnight. If I left the wheel turned (not sure which direction) It took on a whole lot of water. Up to the carpet even.<br /><br />I have winterized it now, and I had tear the starter down and clean it up to get it working again, I assume due to water exposure. I drained the drive oil, and it showed no signs of water (thank god). It is now being stored in a family garage, where I can work on it. Problem is, I am not sure where to start with finding the leak. Could this be the bellows since it is more problematic with the drive turned? Which bellows would it likely be? I read the exhaust isn't a problem on someone else's post. So does that mean it is the drive? What else am I looking at having to repair due to this leak? The alternator seems fine. Is the drive being turned maybe a coincidence?<br /><br />Sorry for the long post, I just wanted to be as specific as I could.
