gardenstatesurfer
- Joined
- Jun 6, 2005
- 75
hi guys,<br /><br />pulled my boat out today and tried to start her, its a 1990 4.3L V6 Mercruiser with a Thunderbolt IV ignition. all im getting is a clicking noise. battery seems ok at 12volts. <br /><br />did some reading on the net and noticed that the clicking noise is coming from the slave solenoid (im a newbie so im pretty proud of this) next to the 50 amp circut breaker.<br /><br />does this mean i need to replace the slave solenoid?<br /><br />i had a similar problem last season...put the boat in the water and it would take a few turns of the key before the engine would turn over. after the boat was run for a few minutes, it would always start right up.<br /><br />i should mention that out of at least 100 tries the engine did turn over once today....i forgot that i didnt have the hose turned on to cool the engine and regretably shut it off before it could start.<br /><br />since then im back to the clicking noise.<br /><br />one other question-does the drive have to be in the down tilt position to engage the engine? i tried this just in case but to no avail...<br /><br />and just for the hell of it i will mention it appears my "trim" up button is not working. down<br />is working ok.<br /><br />thanks for all your help guys, i need it!!!<br /><br />dave
