WhiteyFlex
- Joined
- Sep 26, 2020
- 9
So after 6 years of not having a boat I jumped back in the lake and bought a boat. Picked a 1989 Regal Sebring 195 for a solid price. Previous owner took immaculate care of it. But I am having a few issues out of the gate. Below are the upgrades that were made by PO and the issues I'm currently having.
4/24/01 - steering cable replaced
7/16/03 - shift cables replaced
5/10/09 - replaced original 4.3L V6 with a new 1996 4.3L V6 vortec (and yes the engine was still new although 13 years old) & did most of the other major stuff like gimbal bearing, pumps, carb rebuild, alternator rebuilt
7/24/17 - new drive belts
5/14/20 - Rochester quadrajet carb rebuild, new trim switch and impeller kit
1. Stalling issue - This is the biggest problem at the moment. Had the boat out 2 times and it keeps stalling when shifting into gear. Doesn't seem to matter if it's forward or reverse. Also coming out of gear back to neutral it stalls everytime too. Overall it seems to run good once you have the RPM's up and in gear. The engine will even die occasionally just in neutral if I throttle up and let it back down to idle.
2. Vibration when turning under a load - so if I'm cruising along and I go to turn, I get a deep vibration feel in the boat. Doesn't really seem to do it if I'm going in a straight line. Vibration sensation is there turning left or right
Thanks, Matthew White
