mexicobeachrider
- Joined
- Jul 30, 2009
- 5
I am having starting problems. I turn the key and I can hear a clicking noise comming from the engine bay. I went throught the trouble shooting guide that Don S. posted http://forums.iboats.com/showthread.php?t=167035 and everything worked fine as listed. when I got to testing the starter the light did not come on with my tester, his post said if there was a light then the starter would be bad. My only thoughts are the starter is bad due to corrosion. Batteries are good, lines shot good, throttle lines are good, kill switch is good,,,,, not sure what else to check.
