took-the-red-pill
- Joined
- Jul 24, 2011
- 19
1988-4.3L V6 with cobra leg. 2BBL carb. 16-1/2' bow rider. We tow skiers and tubes.
Two months ago my boat was really running rough. I put in a new carb kit-I'm not an expert, so I just took it apart, cleaned it, and put back together with the new parts, and cleaned the fuel filtre.
After the kit it was starting and running well, but really hesitating on hole shot. As I recall it stalled occasionally. I backed off the idle screws about 1/2 turn and it became manageable, and would not stall.
Currently:
Starts and runs well. WOT is about 4400RPM with my current 15 pitch prop.
Hole shot-I punch it, it hesitates maybe 1/2 second, then takes off. Once it takes off, it feels like normal acceleration.
Sometimes at about 1000-2000RPM, when I'm already moving, if I punch it, it almost dies-the tach drops to 0 for a moment, then it catches and takes off.
A few times, also at that low RPM if I hit the throttle, it has gone, "flup flup flup," and then taken off.
On the advice of my brother, who thought it might be accelerator pump, I checked the accelerator pump by having my son actuate the throttle with it turned off. The first few times, one of the accelerator jets was a bit lethargic, but after that both worked well.
Please let me know your thoughts on what my situation might be, and where to start.
Thanks
Keith
Currently:
Thanks
Keith
