As reported in another post I recently had my old 1988 4.3L OMC 4bbl replaced with a remanufactured Merc long block (identical block.) I currently have about 6 hours on the engine and therefore am in the break-in phase. This involves keeping the RPMs between 1500 and 3000 rpm (about 3/4 throttle) and varying the engine speed.
I have yet to see the engine temp above 125 d. even if I keep the engine at 3000 for over 5 mins. The dealer says this is normal, but I'd like your opinion- seems too cold to me. I do have brand new one-piece OMC manifolds on the engine (yes I actually found some!) whereas before the ports on the old ones were probably restricted somewhat causing the engine (my recollection) to run considerably hotter at 3000.
My understanding is that the pistons are elliptical when cold, and engines should not be run at high speeds when too cold for that reason.
Could someone set my mind at ease that my conditions are normal? I will not be running the engine at full throttle for another 4 hours, and then only sparingly.
Your help is very much appreciated!!
Frank
Frank
