4.3L vortec. Which spark plugs?
Status
Not open for further replies.
fourwinnsdook
Ok, i have an 87 4.3L engine that i recently put vortec heads on. I did it more because the old heads were worn out so i found a manifold and 2bbl carb off of a 2004 marcruiser to put on it. I am now trying to find the best plugs for it. All of the auto 4.3 vortec engines call for platinums is that right. Please help!
Re: 4.3L vortec. Which spark plugs?
Ayuh,...
The MR43T was the plugs for Chevies for Years,...
The Vortec heads take a longer plug,...
MR43TS or maybe it's MR43TL,... Don't remember...
Somebody will be along that knows for Sure...
TilliamWe
Banned
It's MR43LTS The Vortec V8s use them too. The "L" is for "longer reach". Which Vortec heads need.
fourwinnsdook
Thanks guys! i found them at NAPA! the plugs work, but i have a bad miss. i checked compression and it's way off. i never adjusted the valves after i put the new heads on. I'm guessing that's a big deal?
Don S
The valves aren't adjustable on the Vortec heads, you just torque the nut down to 20 ft lbs.
Status
