4.3LX 4 barrel conversion throttle linkage question
Stamey
I am converting my 4.3L to a 4 barrel carb. I have a marine quadrajet I am using and got a throttle bracket with it, but it is different from my two barrel bracket in that it isn't as long and my circuit breaker and other relay that are mounted to the two barrel bracket cannot mount to the 4 barrel bracket. Is there another bracket that is longer that I should use for this, or is there a separate bracket I should use to the mount the circuit breaker and relay for the 4 barrel configuration?
It's a 1996, SN 0F821477
The two barrel bracket is pn: 805489T
The 4 barrel bracket is PN: 805359T Note: I do not know if the bracket that came with the quadrajet is this part number.
I did measure the distance between the throttle cable mount on the carb to the cable mount on the bracket for both configs and they are within about 1/2", so I can overcome that with adjustment, I believe, and I think I can use this bracket just fine, but need to find the bracket for mounting the relay and circuit breaker.
Thanks,
Chris
