fishingdan
- Joined
- Feb 12, 2005
- 1,045
1991 era 4.3lx Mercruiser Alpha One (boat history shows a rebuilt engine installed in 2000 with only about 50 hours since). Boat is a 1991 Cobia Monte Carlo 198ES.
Bought the boat spring 2008. In general, the boat is in great condition and runs well.
I have only had the boat out once this season (fortunate to be busy at work...). In the second half of last season, I noticed the temp gauge was showing that the boat was running warmer than I would have expected.
Prior to the first outing this season, I did normal maintenance including changing the water pump impeller, wear plate, etc. First time changing one on an I/O, but I have always owned merc outboards and have a bunch of experience changing them.
On first outing, I watched the temp gauge and it showed 190-200 during most of the outing. I had some time over the weekend to poke around. I read on iboats about the steering oil coolers and how blockages can occur there if an impeller breaks apart. The impeller that I removed had some splits in it, but didn't appear to have any missing pieces. Just to be sure, I thought I would attempt removing the inbound hose. Once I found the cooler, I quickly realized that there was no way I was going to be able to get to it (under the port engine mount - who's brilliant idea was that?). I figure I'll save this for a time when really know there is a blockage.
I was walking around the marine parts store today and saw a mercruiser t-stat kit. Not knowing the history of the part in the boat, I picked it up and replaced the t-stat tonight. While I was at it, I explored a bit (found those check balls I was reading about) and then moved on to test the boat on the muffs.
Unlike previous running on the muffs, I watched the gauge closely while monitoring the hose temps (now that I know which hose does what) with my hand. I was actually able to determine when the t-stat opened. The gauge climbed up again to 190'ish and I decided to pull out my new infrared thermometer. I took readings all over the place. In general things seemed more normal than the dash gauge was reading.
After about 20 minutes of idling, I found that the tops of the exhaust manifolds were in the 165 (give or take 5) range near where the manifold meets the riser. The risers themselves were cooler (135-140ish if I recall). The base of the temp sensor in the t-stat housing (and the immediate surrounding area) was about 165 while the gauge was reading 190+ at the time.
Are these temps ok? They are certainly not near 200 degrees noted on my dash gauge.
Thanks
Thanks
