The last couple weeks my engine would fire up on the first try then stall. A few tries later it will run for a second but it doesn't do anything after that.
With a shot of ether, it fires right up.
Unfortunalty I was alone each time so I couldn't look into the carb to see if it was getting gas.
So I have two questions?
With the key in the "on" position, there was no power to the fuel pump. Is that normal? Once I get it going it runs fine. I checked the fuses they were fine.
Does the carb have an accelerator pump? I should see gas whn I pump the throttle lever, right (The boat is an hour away so I can't check).
