4.3's best gas mileage
Merc4ever
My buddy down at the lake told me your best mileage is in gear, at idle cruising along like a canoe. Is that true?
I argued that from what I have read it's the sweet spot up on a plane with the throttle cut back as much as possible. Seems to me that it would be terrible mileage because you don't go straight when (off plane) weaving back and forth at idle because the boat is not built like a canoe or sail boat.
Re: 4.3's best gas mileage
Ayuh,... Donno,...
With my 4.3l, in my 21' tinboat I can troll ALL day on fumes....
Btw,.... Who says ya gotta run Straight,..??
Rules just say ya gotta Get there...;)
45Auto
You're right. Best mileage on a boat will be where the lowest point on the drag curve coincides with the most efficient RPM range of the motor. On most planing hulls, that's just after they come on full plane.
Yeah, is your goal to take as long as possible to get there, or to get there on the least amount of fuel? ;)
Easy enough to look up some tests on Boattest.com. Here's a typical bowrider with a 4.3L:
Merc4ever
Ha Ha, Thanks a bunch 45 Auto with your chart it looks like my buddy down at the lake owes me a beer. Idle might be good mileage but not as good as up on a plane and cut back on the throttle!
bruceb58
Depends on the boat and the motor. There was a thread recently that had similar charts with idle being the best MPG. I will try to locate. On my boat with my flow meter/GPS. My best mileage is at around 1000 RPM. My readout is in MPG.
Here is one for an 4 stroke outboard.
Pierutrus
Mine just sips fuel all day long. I re-pitched a prop to 22 degree's and I never get out of recommended RPM range, does 4400- 4600. I have gone 4-6 hours at 30 mph and came back with a half a tank!
Open her up with the 4-barrel and all bets are off!:D
