Got this 1984 (s/n. 6428121) that the previous owner said he never started (not sure for how long), but seems to be in good overall shape. I see sparks when rotated the fly wheel manually (with a regular manual socket and ratchet) but unable to get it started. <br /><br />Then I took apart the carb and sprayed clean all the passages and crevices that I can took apart with Gumout Carb cleaner. <br />Put everything together, pump the bulb; pulled and pulled and pulled the robe: nada! Squirt some fuel in cylinder spark plug hole: nada; squirt some at the carb throat: still won't start at all! I even pulled the kill motor wire: no luck! <br /><br />I also tried to close/open the choke as well as rotating the throttle from Fast to Start to Idle position on any combinations; but never heard any sign of combustion at all. <br /><br />What else can I do to get this engine started? Please help, thanks a lot!<br />Sam
