Re: 4.5 merc point gap
Hi,<br />They rarely go bad. I don't know if I have ever replace one, other than getting ground up in the flywheel
. I think that the insulator that the point spring is attached to with the little nut is cracked and your voltage is leaking to ground.<br />You have to remove the stator and points to check it out. There is no repair to this just replace it. They aren't to expensive. This is the most common and cheapest fix, hope it is the problem.
