4 beeps on 135 optimax
Fastcarrs
New to me boat, and got the 4 beep warning, at idle or low speed not on plane do not get it. Get on plane with higher rpms get warning. Last time out went 17 miles off shore taking my time, not on plane no warning got half way back and put her on plane and after 10 min started to get warning. Got back to the dock took stbd cover off oil tank full, port cover off and tank was only about 1/4 full. Next morning got up took cowling off and the tank was full, started it up and for the hell of it bleed the system. With engine running oil came out.
What should I check and or replace to solve this issue
Chris1956
You can look up the 4 beeps online, and see what it is. Water in the fuel is a possibility, as those motors have a water detector in the fuel filter.
It sounds like you need an owners manual at a minimum. A service manual is probably a good idea, as repair is a lot different than a carb motor.
