4 blade prop
handy69
i have a 1987 Sea swirl topaz sport with an OMC cobra 5.7 liter motor 300 hp and have been using a 14 1/2 x 19 3 blade prop top end rpm is 5400. should i use the same in a 4 blade prop?
top end rpm is 5400
Get a new Tach because your motor is not turning that fast.
Going from a 3 blade to a 4 blade with the same pitch your going to drop RPM around 200
QBhoy
Hi. Think a few details are off. The HP number and the rpm number are both surely wrong. Hopefully the members can help, once the figures are good.
QBhoy
Think that’s generally good advice. But some exceptions for sure AD. I actually found that going from a Merc 4 blade ally 21” to a 3 blade tempest plus 19” dropped the rpm by at least 50-100 rpm (because the 4 blade was on the limiter at 4900/4950) to about 4850 and increased speed by around 5 mph. Just clearly had less slip at the top end
handy69
i should have mentioned the motor had been changed to a 300 hp 350 gm about 6 years ago and i will confirm rpm tomorrow at the lake. thank you for in put.
jth877
Weight of boat? I found the merc/quicksilver prop calculators very accurate. My boat is 21ft, 220hp 5.0L. 3000lb plus gas/meat/gear. The calculator chose a 4 blade aluminum 19p, 14.5" diameter OR a 3 blade 18p aluminum 16" diameter. I opted for the 4 blade.
At a loaded weight of 3500lb, wot was 4400rpm at 47mph. That's the boat speedo not gps.
