4 blade Spitfire prop for Pontoon?
bighermHK45
I noticed that during my testing of the the motor height of the Merc 115 2 stroke on my 24' pontoon, I have very weak water "bite" in reverse and steering at low speed is sketchy at best (not that it is supposed to maneuver like a sports car). But it is noticeable and since my wife loads the pontoon for me since she refuses to back the trailer down the boat ramp, I need to make it as controllable as possible.
So, I have read a 4 blade Mercury Spitfire pontoon specific prop will help with what I am after. Currently, I have a 3 blade Quicksilver Black Max 11 pitch on it now and it seems to perform decent overall. I don't want to lose too much top end if I do switch to a 4 blade.
And lastly, if I do switch to a 4 blade, do I keep the same pitch as the 3 blade or go up to a 13 pitch. The Mercury website prop selector indicates I would gain about 4 mph at top end if I use the 13 pitch. It doesn't make sense to me, but maybe someone can explain the characteristics better to me.
Thoughts?
HotTommy
I don't know the answer. If you don't get a satisfactory answer here, you might want to repeat your question on the Propeller specific forum.
steelespike
Typically it is suggested to decrease pitch 1" going to a 4 blade.I do believe it is usually suggested to use the same pitch with the Spitfire.
Increasing pitch seems unusual but depends some on your present numbers.
4 blades typically improve hole shot, stay on plane easier at reduced throttle,seem smoother and respond better around the dock.
Spitfire is said to maintain top speed but I haven't seem any pontoon numbers.
It seems to me a 4 mph increase is a tough assignment with a pontoon.
Jeep Man
What he said. When I switched to a 4 blade, I dropped the pitch by 1. Speed did NOT change and RPM stayed the same. Hole shot and reverse control was a little better.
bighermHK45
Today, the best WOT was 23 MPH (GPS) at a range of 4900-5400 RPM. The cross/head wind (17-20 MPH) and chop on the water was not ideal conditions for testing. Not sure if this '99 Mercury 115 has a rev limiter or not but when it hit the 5300 - 5400 RPM the motor dogged out and I had to throttle back. Based on the conditions today the WOT averaged 22.5 MPH at 4900-5200 RPM.
So, based on these results, I am guessing I could go to a 13 pitch 3 blade as there seems to be more MPH to be had as the 11 pitch seems to be increasing the RPM before I can get to the maximum MPH?
Or should I go with a 4 blade 11 pitch, which (if I understand correctly) will drop my RPM slightly and put me in the 5250 RPM the manual calls for at WOT?
Thoughts?
Bamaman1
Pontoon boats are displacement hulls, and they have their speed limitations. They'll get up to about 25 mph, and it's like hitting a wall. To get any more speed out of the hull, you've got to have lifting strakes on the hull to get the nosecones out of the water or much more horsepower.
I suggest you go with one of the new model of propellers specifically designed for pontoon boats in a 13 pitch. Mercury and Yamaha both have such propellers. 4 blade props are really seldom seen on pontoons.
I'm running a Yamaha Reliance 15 pitch prop on a 24' Bennington with a F150 Yamaha 4 stroke. I'm seeing 6000 rpm's at 40 mph--just perfect.
bighermHK45
Well, I tried the 4 blade 11 pitch and it did not perform as I had hoped. It definitely had great hole shot but it was a dog at top end. I lost 2-3 MPH and it would only max out at 4900-5000 RPM. Pretty lame. So, back to the drawing board I guess... Not sure a 13 pitch would help my cause or not.
