Scott Kirkman
- Joined
- Sep 18, 2009
- 21
Hey all-
I have a mid 70's 4 cylinder 50 hp Mercury. I'm not exactly sure what year it is because the power head was swapped at some point, the serial number below the tiller shows it to be a '74. I've got the motor idling reliably, but it will only run at top end if I pump the bulb. I'm thinking maybe fuel pump? Anything else I should check? I didn't see any adjustment for float level when I rebuilt the carbs. Not sure if it matters, but I'm running a jet pump.
