4 hp Johnson lower end leak
haz
4 hp, m/n 4837E, s/n E0001374 I could figure out the year from these numbers.<br /><br />First of all, this bottom end only has one oil plug so it's not the easiest thing to fill. What's the correct method to attain the right oil level.<br /><br />also I have some oily/watery goop which looks to be dripping from a very small hole just above the water intake ports. Is this indicative of a bottom end upper seal leak?
Paul Moir
Re: 4 hp Johnson lower end leak
That's a '78 4hp you've got there. The way you fill those is to set the outboard on it's side so the plug faces up, and slowly add lube until it overflows. It's a little tedious.<br /><br />It may not indicate anything - you may be just seeing unburnt fuel/oil from the exhaust. If it smells of gas rather than the stink of l/u oil, that's probably what your're seeing. If the old lower unit lube isn't contaminated with water (coffee with cream colour) this is definitely what you're seeing.
Xcusme
Has,<br />I have found that it's easier to refill the lower unit by laying the motor on it's side with the fill hole point up. I fill the lower unit with fresh lube to a level just below the bottom thread of the fill hole. Be sure to replace the washer on the fill screw too. If this washer leaks, water can enter the lower unit.<br /><br />As for the 'oily/water goop', it's usually normal. It's a bleeder hole to allow excess by products of exhaust and water to drain from the midsection of the motor. Looking at the lower unit fluid, when you change it, will tell if you have water intrusion into the lower unit. The sources of water can come from a faulty prop shaft seal, fill washer leaking, or as you mention the bottom end drive shaft seal. If in doubt, a simple adaptor (at the fill hole) and a bicycle pump can be used to pressurize the lower unit, submerge in a tank and look for bubbles.
Xcusme
Ha! You did it again Paul! I just gotta learn to type faster!!
