bankerjohn
- Joined
- Mar 21, 2008
- 444
Any 4-stroke folks out there who know how the coil is wired on a "wasted spark" system?
My E10FREDR motor has one coil, with 1 connection to the ignition module, and 2 plug wire connections. As I understand it, both cylinders fire at (around) TDC on both the compression stroke, and the exhaust stroke ... thus giving it the "wasted spark" name.
What I'd like to know is, how can such a coil produce a good spark to one plug wire, and an lousy intermittent spark to the other plug wire? The only way I can see this happening is if one of the connections internally to the secondary coil is good, and one is failing ... or there are actually TWO secondary coils in the unit, one for each plug wire.
Anybody know for sure how these units are constructed?
