Re: 40 E-Tec in salt water?
if you read the info on the site the saltwater motors are different<br /><br />Saltwater boaters are a breed apart, willing to stand up to some of the harshest conditions the planet can produce. Of course, they need equipment that's as durable as they are. Evinrude E-TEC Saltwater Editions fit the bill with virtually indestructible stainless steel parts and extensive DeepGuard corrosion protection.<br /><br />Saltwater Editions use a stainless steel steering tube, steering arm, pivot shaft, drive shaft, prop shaft and fasteners.<br /><br />Each Saltwater Edition outboard goes through 14 washing and rinsing cycles, a conversion coating, sealer, baked on strontium chromate primer, and baked-on high solids melamine top coat. The Electro Deposition Paint creates an extremely durable barrier for added protection in a harsh marine environment. Low copper alloy used in the aluminum casing and a split-line gear case further resists and reduces corrosion. And sacrificial zinc anodes absorb the elements of corrosion to protect all operational components.<br /><br />tommays
