40 horse jhonson
KXP
where is the pee hole on this and that is if there is one the engine is getting hot i think it pops before it shuts off
Boss Hawg
Re: 40 horse jhonson
All i know is there is one ;)
If you dont see a pee stream you need to look at your water pump :(
qxlooper
what year for? or is this true for all of them>? I have a 1964 and once it warms up, I get a steady mist, not a stream!
tx1961whaler
Helps to know the year. Later one have a pee stream, earlier ones have an exhaust port that you can see the water come out of. In either case, you should be able to (barely) keep your hand on the cylinder when it's running without burning yourself.
Keep your fingers out of the flywheel.
qxlooper
I have a 1964. i can keep my hand under the water coming out after it has been running for 30 minutes.
tx1961whaler
You can have water coming out of the exhaust relief and still have nothing going the engine.
KXP
mine is rds-23 the bottom has this weird looking exhaust port and i can barely touch it and have to take my finger off that is the head were does the pee supposed to come out of the water of course
