I did rebored the lower unit(changing gasket and seal). The recommendation was to change the impeller at the same time witch i did. I have the motor until a month ago. The problem is: when i drive iddle, the water come out normally from the water pipe on the back of the engine. But when we start to increase the motor medium to high speed, water stop leaking and the motor doesnt appear to overheat. So, i dont do long drive because im affraid to burn the motor. I need help about it.
