40 HP drain and fill o-ring confusion
tgab14
I have a 1990 40HP johnson, J40ELESR, and have some questions about the fill and vent plugs. The OEM parts list shows the same o-ring for both the drain/fill plug and the vent plug. All of the sierra parts that replace the drain/fill plug have a magnetic tip and a allen head with a plastic washer(which is what is currently on my motor). The vent plug is a small slotted head with a small red washer on the plug. If you search the part # for the fill/drain plug it shows a picture with what I have(magnetic tip with plastic washer) but the parts list also looks like it calls for a o-ring? Same with the vent plug, the o-ring is on the plug but also shows same o-ring for the drain/fill plug? I cant find a part # for the just the small o-ring on the vent and a part # for the plastic washer on the drain/fill? Any help? I've read through past posts about these gaskets and it adds to the confusion.
Tim
D
DJ
Guest
Re: 40 HP drain and fill o-ring confusion
BRP/OMC part #: 0333572 (shown as O'ring").
Same for Vent and Fill.
tgab14
Mine also has a washer on the drain plug. When I boat the OEM plug with the part # in the above link it came with 1 washer. The vent has a small o-ring that is not the same as the 0333572 that came with the vent plug. Do I also need to use the bigger o-ring? I'm thinking not. What is the part # for the washer?
