nasty79z28
- Joined
- Aug 11, 2010
- 32
Tuning up the engine on a boat I just bought, its a TJ40ELESR. Sat for five years with zero attention. Got it running but seemed a bit sluggish out of the water so didn't even try to put it in. Kinda suprised it started so quick and had water pressure.
What I've done so far. The lower unit is off getting a new skeg welded on. Going to change the water pump, plug seals and fresh oil. Also found the plastic piece the shift linkage rod goes through to the lower unit leaking, ordered parts to reseal. Pulled the carbs off and rebuild. (Sierra carb kits worked awesome!) New spark plugs on order.
Is there anything else I should do while I have the carbs off? Anything else I should check to make sure this thing is going to go when I put it in the water? One other thing I noticed is the vacuum line going from the crankcase to the intake manifold has some old gas in it (looks brown). Should I spray it out with some brake clean to help remove?
Thanks in advance, Kyle
