My 1986 Yamaha 40 3 cylinder started acting up this week. Runs like a top when for first hour of so on the water then intermittently loses both bottom cylinders at idle. If I let it idle for a while they will pick back up again, may run fine for a while then starts acting up again. It runs great at WOT, this just happens when it's idling. I've got good compression on all three cylinders and I don't think it's fuel related because when it's acting up I can pull the plug wires off the bottom two cylinders with no effect on how the motor runs. Any help would be appreciated.
