40 HP Mariner on a 1985 Tracker Ignition Issues
banchigu
Hello everyone I would like some advice on an ignition problem. My key ignition switch on my Tracker finally crapped out on me after 22 years and I replaced it. I replaced it with a generic magneto switch and the on and off works fine. However, when I run the boat it misses (it also did this when the old switch was on its last leg) and after running it and placing it in neutral the bendix pops back up and engages the flywheel. If I turn it off and turn it back on it will go back down after turning it on but return to the up position after running it a bit.
Any help folks.
A million thanks in advance.
