Re: 40 HP Merc Fuel Duration
I'm certainly not an expert on that particular motor and less familiar with the boat. If the boat is comfortably on-plane at 1/2 throttle I would guess somewhere in the 3.0 gallons/hour range. 4 to 4.5 gallons/hour at wide open throttle, maybe more. Whether or not this is a good engine depends on the care its had. If it has not been used in the last 20 years some serious maintenance needs to be done. Thermostat, water pump, lower unit lub change, and carb rebuilding to name just a few things. Apparently fuel consumption is an issue with you so carb rebuilding is essential for best performance and its insurance for best engine longevity. Clogged jets means lean mixture. Lean mixture leads to engine melt-down. No water (as in bad water pump) means no cooling leading to overheating and engine melt-down. Water/corrosion in lower unit leads to failure of the lower unit (as in $$$$$). Stuck thermostat leads to overheating and engine melt-down. See what I mean?????
