kellmike626
- Joined
- Sep 19, 2009
- 104
Just recently bought a pontoon boat that came with a 40 HP Oil Injected Mercury Outboard motor (4-cylinder). Runs great, starts up on first try. The Boat itself is a 1993, so I'm not sure if the motor is the same year.
I've had experience with one outboard motor before, which was a regular 2 stroke 40 hp Merc (premix). But I'm completely new with oil injected motors.
I know the instructions to follow for winterizing (change out gear lube, fogging cylinders, and everything else) but what I'm wondering is if there's anything different needed to be done for oil injected outboards...would I have to change out the oil in the reservoir? (probably a stupid question...) Or anything else different?
I know in the spring time, I heard that it's best to run a 50:1 mix in the tank just to make sure the oil injection system is working. Can somebody confirm this as well?
I will try to find out the year of the motor so hopefully I can get more information on it. I haven't got a manual so I'd better order one too.
Thanks for any help.
