PanamaRanger
- Joined
- Sep 3, 2009
- 19
I have a 1996 Yamaha 40 HP.....A couple of other motors I have had in the past had oiler problems and I had them unhooked and manually mixed the oil...in some regards it seems safer...they were NOT Yamahas. I actually had one Merc 150 lock up because the oiler hose broke inside the motor.
This Yamaha does not pump from a remote reservoir...it has a small tank inside the motor cover you keep full.....My question is --- would you advise disconnecting and manually mixing to be safer? Do they give trouble very much? I bought the motor this past spring -- used--- and can't handle a big repair and just want to know the smartest thing to do. Any advice on it or the reliability of what is there would be appreciated.
