400 OMC
olbuddyjack
I just picked up a 400 sbc from a 77 Blazer for my 87 Bayliner/OMC. What would be the better heads to use, the original 400,s or the 5.7 OMC,s?
Re: 400 OMC
The heads off your 350 will need a trip to the MachineShop before they can be used(they need Steam holes added)..............<br />I'd have the 1s off the 400 cleaned up,+ sharpen the valves..... then use them.......
olbuddyjack
Re: 400 OMC
Thanks for the reply, Bondo. I was flipping back through some earlier post and seen one from Rodbolt that said the 5.7s could suck a valve if they were lugged. Hopefully the older 400 heads are more durable. I'm gonna take your advice and clean up the 400s. Thanks again!
Rainmaker
Re: 400 OMC
You may want to check combustion chamber size. The 400 SBC always used 76cc combustion chambers to keep the compression ratio down. <br /><br />If the 5.7 heads you have have smaller chambers, the compression ratio will go up dramatically. This will cause detonation (pinging) and death of the engine.<br /><br />This site lists combustion chamber sizes based on casting numbers: http://www.mortec.com/ <br />mike
