wannabewelder
- Joined
- Aug 10, 2018
- 71
Hi Guys, researched the heck out of this one and I'm coming up nada.
Bought a 40 Evinrude and it had a bad point. I ordered points and condensers and in the mean time did a pressure test & reseal on the gearcase.
Got everything back together and it starts like a dream but the first thing I noticed was excessive back pressure out the exhaust and it doesn't sound like my '69. I then noticed there was no water coming out the exhaust and then threw a pyrometer on to confirm my suspicions.
The impeller is new, seals are good so I tore the head off since it is easy and I had a gasket. Was figuring it would have a hole in it and it did not. Compression 115/118 lbs.
Tore the exhaust cover off, cleaned & resealed, nothing remarkable. Changed base gasket while power head was off.
Not fixed.
Tore gearcase off, clamped a garden hose onto copper pipe and tried to flush. At one point water gushed out and then we did something and it stopped. Motor was in upwards tilt.
Loosened power head screws, tried again. Nothing leaked around base.
Pulled power head off. Turned water on and it shot out of lower unit.
Checked again, nothing plugged. Reinstall power head, turn hose on and check ports around cylinders heads gasket loosened.
Water now comes out. bolt everything back together, turn hose on and water shoots out exhaust. Bolt gearcase on......nothing. Engine is hot ansd runs like a bag of crap. Yesterday it idled fine
I checked online and cannot see where the thermostat should be. I thought however the water runs on a bypass which does not explain why this works intermittentl. Had this happen in a sunbird heater outlet once and needed a drill to break up sludge. The Evinrude is clean inside.
thanks in advance.......
Not fixed.
