Ill try not to make this too long, but here goes: Evinrude 40HP Big Twin 1970 Model #40052A, Serial #E01672. Put in new premium gear oil and new Champion J4C plugs. Compression was 105 on both cylinders, telltale showed good water flow. <br /><br />I took it out (it is on a 14 MFG Carefree 1970 boat) on local river and it ran super. After having it out for a couple of hours cruising around going all out sometimes, and crawling sometimes, I wound up crawling for about 20 minutes when I decided to anchor up. I put it in neutral, and it ran rough and conked out. When I tried to start it, it would crank strong, but not fire. Gas was getting at least as far as the carb. A nice person on a waverunner towed us back to the dock.<br /><br />When I got home, I checked the plugs, one was oily and one looked dry and burnt. I tried to check if it was getting spark, but I dont know if I was doing it right. I took the boots off the plugs and put them near the engine while it was cranking
nothing. I cleaned the plugs and put them back in, still nothing.<br /><br />After many attempts to start it, it suddenly didnt do anything when I turned the key. I then traced to what point the current from the battery was going and found that it was not going through the solenoid when I turned the key switch. Tested the starter by jumping it to the battery and it worked fine. I then replaced the solenoid with one I had from a previous event, but it just made a clicking noise and eventually made no noise at all. I dont know if that was any good or not, so I have ordered a new one, which I should have by Thursday (tomorrow). <br /><br />Then, I wanted to test compression, so I attempted to do it by jumping the starter to the battery
first try the starter cranked strong, however on subsequent tries it slowed considerably (enough that the bendix would not engage the flywheel). Therefore, I then hooked up an alternate source of power (12V/15AMP start off a battery charger), and the motor would crank
but only without any spark plugs in it. When I put one or the other or both in, the bendix would engage the flywheel, but would only moaningly turn it.<br /><br />So, what do I do next? <br />
