Phillycyclocross
- Joined
- Apr 7, 2022
- 1
So as the title says, I'm having issues with my boat motor. Bought a '94 Bass Tracker last year that has a 40hp jet on it. So far I've done the following to try and fix the low rpm issue:
Rebuilt and cleaned the carbs (3 times new jets. Everything reset to factory spec), changed all fuel lines, rebuilt feul pump, changed all filters, checked compression (120ish on all 4), new spark plugs, new wires, 4 new ignition coils, emptied fuel tank and replaced with all non-ethenol gas.
I believe that's it but there may be more. After all that nothing changes. I fire it up and when I hit the lake I get maybe 2500 rpm and with the throttle buried I'm barely moving. At a loss. Any suggestions would be helpful. Thanks
