40hp Johnson to 9.9hp Evinrude/Johnson
Buster_boy
My pontoon currently has a 2000 40hp Johnson with top mount OMC controls, elec. tilt/trim, gauges. Would the controls and ignition be compatible if I swapped it for an Evinrude/Johnson 9.9hp? Or atleast close enough with some minor changes
I'm asking because I also have a Merc 9.9hp installed as a kicker and have been considering selling the 40hp and using just the 9.9hp (I'm on restricted waters), but converting my helm from Johnson to Merc would cost about $1,000 and some down time out of the water. I don't know why I didn't think of this sooner but why not sell/trade the Merc 9.9 and the Johnson 40 for a like branded 9.9 instead? That way I don't have to convert my helm and can make the swap in a day or so's time.
MH Hawker
i found a merc controller on e bay for 150 when i converted to a 9.9
oldboat1
Controls typically go with the motor. Not as bad as it sounds, as you will probably have an easier time selling the 40 (and more $$), and and easier time finding controls after you settle on a 9.9 model. Later models will have a tilt tube for steering hook up. I use a single lever controller for my 9.9 throttle and shift (trolling motor), and kept the electric start button at the motor -- works out fine for me. Probably a good idea to take a trip to a dealer and see what a full remote setup would involve with one of the new 9.9s.
Buster_boy
See, I asked in another forum what I would need to swap the Johnson for the Mercury. One guy came back with of everything I would need - controls, ignition, cables, gauges, harnesses, etc. I already have most of that in my side mount controls except for the top mount binnacle and Mercury gauges.
The list was all Gen II. I don't know what my side mount stuff is, if it is Gen I or II. It's Quicksilver model #881170A12, and the power cable is 84-892329A01 if that helps. I don't have a number for the cables though. If I knew what Gen they were and if I knew I could disassemble the side mount and use them in the helm I'd do that instead. I'd need to know which binnacle would work too (I know there's tons of them).
Buster_boy
I'll resurrect this question. Can I swap my 40hp Johnson for a 9.9 Johnson or Evinrude and use the same OMC control box?
