dogpaddlin
- Joined
- Aug 7, 2008
- 10
I have a 1970 40hp Johnson electromatic shift motor that does not want to go when I put it in gear. I know the prop is spinning when in the driveway, but when I get it in the water all it does is churn the water behind the boat, but wont push it. I have checked the shear pin and it is fine.
A little more background, the motor was originally on a 1970 model Tri Sonic that had a rotted transom. The motor had never given me any problems until I tried to swap it onto a 1971 Glastron. Both boats were 15ft long.
Is it possible that I just need to adjust the cable length? Could changing out the fluid help?
