tashasdaddy
- Joined
- Nov 11, 2005
- 51,019
timing usually causes backfire. check the center of you flywheel. there is a groove with a metal key. if this is not perfectly lined up the flywheel had to be pulled (special process) and a new key installed. the proper compressio is not published by the MFG. anything over 100psi and with in 10% of each other is considered runnable.
