twintrades
- Joined
- May 7, 2008
- 305
OK when i barell test the motor everything is just fine. Forward reverse and nutral. But when im out in the lake underway Wot it will slip into nutral. But if i give it a little gas and walk to the motor i can hold it forward more than the cable does and it will stay in gear. Only if i hold it though.
I had to recently replace a bolt in the lower unit / upper shaft conector
Is there a posibility i dident have the lever in the right position when i conected the rods? Is there a proper procedure ?
Oh and the lever is a little sloppy too. Is there away to tighten it?
Model is an RD250 i think it is a long shaft or there is an extention put on it.
Which by the way how do i know if i can remove the extension ? And is there a way to know if its an extesion or if it was built that way?
Thanks sorry for all the questions
