I have a 1990 40 hp with a trim assist cylinder.
That means that my trim does not work. It has been stuck in the down position since i picked up this boat about a year ago. I under stand that this in not an uncommon problem. My question is has anyone came up with a solution that doe not cost $500? If you look on the used market, the power trim system is in high demand, and typically will run you north of $500. I have found two aftermarket systems, both run over $500. What have you guys came up with? Maybe addapt a Mercruy trim unit, or one from a differnt year Johnson or one from the three cyclinder Johnsons?
KP
KP
