40hp vs 50 hp yamaha
bobby711
What's the 10hp difference were the horse power hiding , carbs .. Reed valves ??
Have a 89 40hp yamaha would like more speed .
boscoe99
Open up the Yamaha parts book for the 40 HP model. Open up the Yamaha parts books for the 50 HP model.
Compare the part number differences. You will have the answer to your question.
Sea Rider
Need to prop right for the motor to run at least middle of its wot rpm range although max wot rpm range is preferred. Will need to install an induction tach for that enterprise, go for a wot run as usually loaded and compare the max wot rpm achieved to the min-max wot rpm range factory stated and install a less prop pitch from current installed prop to pull wot revs higher...It's much cheaper than swapping 50 HP motor parts to a 40 HP motor.
Happy Boating
