42 amp alt ford 302 engine
Jakem
What do we make of this issue
  • 20221231_113459.mp4
Jakem
I've had it replaced...I think it's time for a new alt
Have the alternator tested. My last rebuild went back twice. Two bad regulators out of the box
sam am I
There might be a bad diode(output seems a little low) perhaps creating enough extra noise to make the meter jump around, but also think its the meter having sampling issues with a bit extra alternator noise ........If this measurement is from the B+ of the alt., then of course the battery is connected to this wire and with good/clean connections yet your meter is flipping around as low as 0.26V, 0.63V, 1.63V while connected to a 12V lead acid battery? Not entirely real readings, the 12V lead acid ain't going to drop like that, not that fast and esp not that low.
dingbat
Agree…if the battery isn’t connected it could be the regulator bouncing around trying to regulate w/o a load.
Couple of points about the meter:
2.5 second update rate
No auto ranging - manually select DC or AC
HV - high voltage or DC - not shown on display in picture
Would like to see same test done with a load on the circuit
Jakem
had it tested...no good...I bought a rebuilt self exciting 1 wire for 160 bucks. Works great
Make sure you have a battery disconnect switch with a 1-wire alternator
Jakem
I will get a new one and install it. I had one but it seemed broken on the inside. Didn't trust it.
