All -
I have a Martin 60 that is running poorly at higher speed. It will start fine and run around the "Start" position. However, as I increase speed and load it smokes, and will not rev very high. It sounds (and smells) like it is loading up in a rich condition. It also seem to run best as I lean out the mixture, but to a point where it eventually starves.
I have filed points, checked coils, confirmed I have spark. I soldered new spark plug wires a couple years ago. I have also cleaned and checked over the carb. Everything looks clean and sprayed through with cleaner and air.
The only thing I can think of (but am looking for other opinions) is the float height. I looked in a manual and it's not very clear how to check this. Does anyone have a practical means of doing this?
I'll quote the manual: "FLOAT LEVEL: Distance from top to float (at free end) opposite needle seat to lower edge of float chamber when needle is seated to be 1/8in +/-1/64in.
Thanks,
Matt
Thanks,
Matt
