48 hp spl still dies out at 2900 rpm
pete6464
ready to give up.rebuilt carbs ,rebuilt fuel pump replaced coil also ignition module still dies out at 2900 rpm ,need help
Joe Reeves
Re: 48 hp spl still dies out at 2900 rpm
If you have compression and proper spark, you've either overlooked something within the craburetor(s)..... high speed jets? Or.......
The timer base is sticking (retarded spark). OR......
The throttle butterflies are opening before they should in relation to the timing (carb roller, scribe mark on cam).
