69starcraft
- Joined
- Jul 11, 2007
- 169
Noticed yesterday after running the motor in a barrel for a bit that I had a thick looking oil coming from a small weep hole on my lower unit. It is on the starboard side right below the water inlet holes.
Since I haven't done anything but idle her once or twice in the barrel so far decided was a good idea to get around to checking the Lower unit oil.
Pulled the plugs, came out pretty Grey.
So I let her drain, and then refilled the L/U with fresh oil.
I was going to run again in a bucket later and see what happens when I check it again.
However, I STILL have a small amount of gear oil coming from this weep hole. I drew a crude circle around the weep hole, and a crude arrow pointing to a Phillips screw of which the function I am unsure since there is also a top and bottom Flathead drain screw??
From what I read by searching the forums this hole is supposed to be for draining unburned exhaust oil/gas but mine is definitly leaking gear lube.
I'm a mechanic by trade, I know the difference and it's hard not to notice that rotten smell.
So my question is what seal is bad or what could be wrong that would cause the fresh gear oil to weep from this hole?
An overnight sit had produced enough leak that there was a "drop" of lower unit lube hanging from the skeg, but none had actually dripped to the ground. So it's not leaking very fast at all. But oil out can mean water in.
Since I have fresh oil in it now would it be all right to take to the lake and at least run it for a sea trail (then come home and check oil again) I've never used it yet, but verified Fwd and reverse and no scary noises while running in the barrel. I would like to at LEAST try it once, and then maybe rebuild the L/U or sell the boat
BTW I saw no Nylon washers on the Drain Screws....the screws have rubber washers look like they are built onto the screw. I will be replacing them
I have a Seloc manual but as I found out (and you already know) they are not so good...
