Re: 4806E fuel pump
Word of warning about that Sierra 18-7350 replacement fuel pump. I just got one for my 1967 20 HP Jonson, and I had to do a bit of finagling to get it installed. The back plate (the one that sits on the gasket against the motor) is thicker than the original fuel pump my motor had on it, and it caused problems in that the original screws are too short to get through the pump, gasket, and into where they thread. I purchased longer screws (2" vs 1-1/2" 10-24 screws), but then ran into the problem that there was not enough room between the motor housing and the motor to get those screws in, so I had to cut about 1/4" off of them. Even then, the space between the motor housing and the screws before they are tightened was not sufficient to get a screwdriver in there. I had to finger-tighten the screws until there was enough clearance to get a small screwdriver in there. With the pump in place, the screw that holds on the screen filter is practically touching the motor cover, such that to replace the filter, I'll have to remove the whole pump in order to get that filter cover off.
-Eric
