This motor is new to me but the original owner said it needed a carb cleaning once per year and ran allright.
The switch and battery wire went bad soon after I got it. I ran a jumper wire to the new switch battery terminal.
After cleaning the carb twice it started and idled for 10 seconds and quit with the throttle in neutral.
After that it would crank a few seconds a quit. If the plugs are out it cranks normally. The carbs have flat tops with gaskets if that means anything.
The model number is: 1996 J48ESLEDC
04071701
What is happening here? Thanks.
04071701
