Hi Everyone
This engine has got me baffled.
It Idles rough (missing) & gets more noticeable as you increase throttle & it seems not to beable to reach WOT(5000-5500), I don't have a Tack installed. I'm not a O/B mechanic.
I'v read the Seloc manual, read all you guy's post on mercury 4cyl's in that year range.
While running at Idle I'v sprayed a oil/gas mix into Carb's-no noticeable difference. I'v pumped the primer bulb-no difference. Sprayed carb. cleaner in & around carb's to see if there was a vacuem leak-no change.
Plugs are new, spark is jumping great, even checked at night to see if there was any spark arcing anywhere-nothing.
I put my inductive timing light on each spark plug wire one at a time the light flashes beautifully.
Everthing seems to be in order, can I still have a stator or trigger problem even if it seems the plugs are firing ok ? or could the timing be out of whack ?
But timing wouldn't necessaryly create a Missing situation, I don't think. That would only cause maybe a sluggish acting engine.
thanks
Centani
Mass
thanks
Centani
Mass
