4HP Johnson cooling problem
theonn
I have a 1978 4 HP Johnson that has been overheating. I removed the water pump, it looked ok but will replace it. I hooked a water line to the water tube and got no flow through the engine. Then removed the exaust and water tube assembly the hole in the block si blocked. Is this a thermostat or a blockage I need to clear? Roger
Zeeter
Re: 4HP Johnson cooling problem
They get clogged where the powerhead attaches to the leg. Take off the powerhead and youll see it. Its an easy fix all you need is a new gasket.
pacman77
Re: 4HP Johnson cooling problem- mine 6hp
does a 1972 6hp CR72D have a thermostat??
Vic.S
6R72D you mean!
Yes under the cover held by three bolts on the top of the cylinder head.
#23 inTHIS DIAGRAM
