4hp Johnson - which hole is the water tell-tale?
labougie
It's a 1996 BJ4BREDS which is new to me and has been used in salt water. I separated the powerhead from the leg, did a bit of cleaning up and put it all back with a new gasket. I've replaced the impellor. I'm now getting loads of (hand-hot) water out of C and only the odd trickle out of B and A. Is this as it should be? Is C actually the tell-tale? Thanks in advance.
image.aspx
